#1
91 silverado 355,carb.
Hello.I have a 91 silverado,regular cab, shortwheel base,two wheel
drive. I use truck everyday to go to work, and I pull a small aluminun boat and use my truck in the woods.Like to hunt. I want to hop-up my truck alittle,motor needs overhaul and needs a transmission. I was thinking of this, I have a th350 in very good condition in my shop, and I saw several different combinations. What do ya'll think about this? 350,bored.030 and decked dart 165/1.94/1.5 valves,( i saw vortec make good power, but i rather darts, vortec are too thin for me) kb120 fkattops (looks like 9.5 compression) cc roller tip rocks and cc dr timing chain cc xe262 cam 650 holley carb. a manifold with rpm range upto 6000 my rear end,i already put a 3.73 positve i putting heads too Did I miss anything ? Register now (free) or login to remove ads |
#2
Nice little torque motor. Use 1 3/4" long tube equal length headers with "X" pipe just behind the collectors, 2 1/4-2 1/2" pipe to the back with mufflers of your choice. RPM intake. All done by 5K.
RPM HP TQ 2000 154 404 2500 195 409 3000 242 424 3500 290 435 4000 326 427 4500 353 411 5000 364 382 5500 325 310 |
#3
The usual primary would be 1-5/8". Where does the 1-3/4" pipes overtake the smaller ones?
#4
The slightly larger primaries show more torque and hp throughout the range. If you think about it, we used to use 1 5/8" primaries on 265 and 283 Chevies. These are 355's we're talking about here, so they need a little more pipe.
If you do a little math, you can see it easier. A 1 5/8 pipe is 2.07 square inches in area. A 1 3/4 pipe is 2.40 square inches in area. The 1 3/4 pipe is 16% larger. A 350 is 23% larger than a 283, so even at 1 3/4, the pipe might be just a tad small in comparison to what we used to run on those little mouse motors. See how my mind works?
#5
I got your reply,techinspector, Thats some really good power for me.
Thanks for the advice with the headers and pipes, I hadn't thought about that part yet. You said an rpm manifold, I'm assuming you mean an Edelbrook RPM manifold. I'll let ya'll know in the future how it went.(hopefully by 6/30/09) Thanks from, Blazer53 |
#6
Yeah, it doesn't necessarily have to be an Edelbrock, but a dual-plane, high-rise such as a Weiand Stealth or Professional Products Typhoon. Use only 1.5 rockers with that cam. That's the way I dyno'd it for you. In my opinion, using 1.6 rockers with an Extreme Energy cam is asking for trouble. Set your squish to somewhere between 0.035" and 0.045". Again, in my opinion, this is one of the most important aspects of building a street motor that will run on pump gas without detonation. This motor will be building considerable cylinder pressure and could rattle if the squish isn't right. The stack of parts you're using adds up to 9.001". The nominal block deck height of a small block Chevy is 9.025". If the block is virgin and has never been decked and you slap it together with a run of the mill 0.040" head gasket, the squish will be 0.064" and you could be in trouble. You can use a thinner gasket so that you don't have to cut the block decks so much. Victor Reinz makes a #5746 composition gasket that compresses to 0.025". With the piston down in the hole somewhere between 0.010" and 0.020", you'd be at your target squish and all will be right with the world. |
#7
Hello techinspector1, I looked at the intake manifolds,I think the
weiand slealth,part # wnd-8170 daul plane seems good. But is the bolt pattern different on that year (91)? Also i looked at your dyno shows up to 5500rpms. The manifold including Edel. has rpm range 1500-6700. XE262 shows rpm range 1300-5600. Does that matter? Or make a big different compared to a manifold that makes power from idle-6000, or from 1500-5500rpms? Also I read up on deck height I understand about that part. Thankyou for you help,from Blazer53 P.S. I was looking at the weiand air striker too which is simular too the edel.rpm air gap, but I think the bolt patteren on this engine is different, center bolts look like they come straight up and 8 outsiders are angled. Part #wnd-8501 from Summit. Last edited by Blazer53 : 04-05-2009 at 11:55 AM. Reason: Looking at striker manifold too |
#8
The following is just my opinion.
Edelbrock made a marketing blunder when they called the Performer a Performer. They should have called it The Chump and described it thusly: "Lightweight aluminum replacement manifold to take weight off the front of your car and provide carb to hood clearance". The RPM is mis-named. It should have been called the Performer and described thusly: "Lightweight aluminum manifold that produces maximum horsepower and torque on street motors from idle to 6000 rpm's. Over 6000, use a single plane intake manifold." Here's a Vortec style manifold. Two bolts in each corner for a total of 8..... http://images.google.com/imgres?img...3D2% 26hl%3Den Last edited by techinspector1 : 04-05-2009 at 02:52 PM. |
#9
91 sliverado 355,carb.
Hello again,techinspector1, I can't use vortec manifold. I did some
checking about this motor. I bought the truck two years ago used so I called the guy up and found out that this was an exchanged motor and and the bolt pattern is of a latter model. the 8 outsiders are angled and the 4 middle are facing more downward. I don't think Edelbrook makes an rpm manifold like that. If I wrong about Edelbrook, can you help me with the right part #?, If not I might go with a weiand stealth or an weiand action plus-(which is good to 6000rpm) |
| Thread Tools | Search this Thread |
| Similar Threads for: "91 silverado 355,carb." | ||||
| 91 crown vic 5.0 a HO? | Wilnutt | Engine | 15 | 05-27-2008 09:50 PM |
| 91 silverado chopped top how to | student blake | Body - Exterior | 0 | 07-02-2006 10:35 PM |
| 91 chevy van | da1965 | Engine | 1 | 06-19-2006 11:44 PM |
| 91 chevy | da1965 | Introduce Yourself | 1 | 06-19-2006 04:57 PM |
| 4.3 to 350 swap in '91 Chevy | V8 S-10 | Engine | 0 | 06-10-2003 01:35 PM |
