91z 700r4 to th350 conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2005, 06:38 PM
im new to this. I took out 700r4 and had th350 that was good and started putting it in. there are bolt holes for the crossmember that i need but do you know what kind i need to get. also torque bar will not bolt to 350 any ideas?
Old 06-23-2005, 06:48 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
there are conversion kits for this. you need a 9 inch tail t-350 tranny and the proper kit for the torque arm to mount.
Try Jegs , Summit , a google search may help, a Camaro specific board where guys probably done this many times.
It does seem like a backward step to install a t-350 tranny. Many guys change to a 700 in early cars that it was not offered in
Old 06-23-2005, 06:54 PM
thanks never done this before not alot of cash
Old 06-23-2005, 07:38 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
if you have little cash , not sure what the best avenue is.
It takes cash to swap to the 3 speed auto & it takes money to build the 700 tranny if needed.
Old 06-26-2005, 03:24 AM
Silver_Camaro's Avatar
Superior Wheels Quality Tech
Just swap tailshaft housings to solve your Torque arm problem. They're interchangable.
Old 06-26-2005, 10:21 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
swapping a 700r4 torque arm style tail housing onto a t-350?
that will solve nothing. The t-350 main case is shorter , the torque arm will not meet up with the torque arm mount
Old 06-29-2005, 07:46 PM
700 to 350 conversion
where are you at in n.c? i have the parts to do the conversion, i have driveshaft, torque arm, crossmember, and torque arm mount. i got them out of an 82 camaro. the swap was common on the early 3rd gens. shoot me an email if ur interested.
Old 06-29-2005, 10:10 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
there is a good solution.
T-350 to 700r4 swap? trumick Transmission - Rearend 6 09-23-2005 08:19 PM
th350 low roller clutch and 700r4? Tissue Transmission - Rearend 4 05-16-2004 10:23 AM
85 camaro 700r4 to th350 drewkuch Transmission - Rearend 5 11-09-2003 09:48 AM
92' 700r4 to th350 swap speedo problem Gojo Transmission - Rearend 1 09-30-2003 10:11 PM
700r4 to th350 transmission conversion Ralph Horak Transmission - Rearend 2 01-12-2003 10:23 AM
