Thread Tools Search this Thread share on Facebook
  #1
Old 03-14-2009, 11:25 AM
41CHEVYCOUPE 41CHEVYCOUPE is offline
Last journal entry: new bracket for the ev-100 controller
92 305 Tpi
92 Camaro runs great, after 20 miles when I slow down to stop the engine dies. It will start back up, but every stop it dies...
Register now (free) or login to remove ads
Old 03-14-2009, 12:03 PM
curtis73's Avatar
curtis73 curtis73 is offline
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
Automatic tranny? could the be the TC staying locked. That was a relatively common thing. The TC doesn't come unlocked, it stalls the engine, then without any pressure in the tranny it lets go.
Old 03-14-2009, 07:08 PM
fast68's Avatar
fast68 fast68 is offline
likes chevy trucks & boobies
howdy there.
you should be able to unplug it and try it without and see if the problem disappears. if so then get a new lockup solenoid for it, its inside the tranny where the wires go inside the tranny aobve the pan inside the tranny.
its a very common issue although i have mostly seen it occur on front wheel drives, IE the 4T60E trannies for example
on those i always jut unplug them and let them go on their way for ppl because they simply cant afford to have the solenoid replaced
i have been told that its better to leave it in working order because apprently it keeps heat down on the highway when its needed to lock up the converter.
i have no idea if thats true or not though
good luck
Old 03-15-2009, 06:43 AM
Will this hurt the trans if I just leave it unplugged for awhile ?
Old 03-15-2009, 09:14 AM
cobalt327's Avatar
WFO
Wiki Edits: 1,616
Some additional heat will be generated like 41CC said- something like a street performance torque converter does.
As long as you're not doing the Cannonball run and your cooling system is working properly, you'll be OK until you fix it, IMHO. Now'd be a good time to check the radiator level!
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "92 305 Tpi"
ThreadThread StarterForumRepliesLast Post
305 TPI to 350 TPIParisienne70Engine105-06-2008 01:23 PM
92 305 Tpi Problem!!92camaroZ28Engine203-19-2006 12:59 PM
305 TPI swap to a '76 350, can it be done?70birdEngine1212-22-2004 12:39 AM
Selling price for 305 Tpi?Chevy Thunder2Engine303-24-2004 04:25 PM
Carb'd 305 to TPI 305, help?coolerowEngine209-23-2003 03:10 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
