'92 318 Dodge engine dist. turning*#@&#@ - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2010, 12:07 PM
Forgive me guys, I'm not very well versed on these mopar engines. Took a young (55k) engine out of a 1 ton Dodge van to put into a project and it's runs(ran) very well.
To get to the point... If I turn the distributor to where the idle sounds/feels good and turn the a/c all the way up it will shut off in just a few minutes So, I turned it back to idle a little higher and it does very well with a/c running but, the trans jumps into gear F/R because the idle is just a little too high.
Old 08-28-2010, 01:48 PM
sbchevfreak's Avatar
Licenced Automotive Technician
Ignition timing is not adfjustable on these engines, turning the dizzy is just goofing with the cam/crank sync. You do need to reset this sync for it to run properly.
Set motor up to number one compression , and then keep turning the crank until you get to TDC. Hook a digital multimeter to the cam sensor signal wire and turn the distributor until you see the meter deflect from zero volts to five volts. Keep fiddling with the dizzy, until you get the voltage around 2.5 volts or so, then lock it down there. This will sync the cam and crank sensors, and provide proper injection timing as well. Of course, if you have scrapped the EFI, this does not apply.
Old 08-28-2010, 06:27 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
Hey sbcfreak werent these engines noted for intake leaks ?Kinda sounds like the root cause here.
Old 08-28-2010, 10:09 PM
randolphi's Avatar
Asuming you scrapped the computer idle control.
you might need to have a relay added to the ac switch and find a small solenoid to mount on the accellerator linkage, adjustable to raise idle only when ac is on-----
Old 08-29-2010, 10:45 AM
Yeah, they had issues with the intake plenum floor gaskets leaking, and causing an internal vacuum leak. Could cause poor idle, surging, backfire, ping, ect. The corners were also known to leak coolant, if not impeccably clean when assembled. Easy way to look for this leak was to hold the throttle wide open, and lookm down the throttle body with a flashlight. If there is oil/liquid on the bottom of the intake floor, the gasket is leaking. All the magnum engines using this intake design had this issue, from the 3.9 to the v10.
acceleration flat spot in carb. corvettetonybone Engine 17 04-13-2013 08:31 PM
1990 318 engine johnnymopar Engine 5 07-30-2011 09:03 AM
56 dodge truck engine swap question 56dodge Engine 1 07-31-2010 02:33 PM
Questions about a Dodge 318 RatFink9293 Engine 2 06-16-2003 07:49 PM
dodge 2.2 engine Terry Davis Engine 7 04-22-2002 09:22 PM
