92' 700r4 to th350 swap speedo problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-30-2003, 08:58 PM
Question 92' 700r4 to th350 swap speedo problem
I am changing trans. from 700r4 to th350 longtail in my 92' Chevy Conversion Van. The 700r4 has an electric plug on the side of the tranny where the speedometer cable should be. What should I do now? I have everything else to do the conversion (kickdown cable, crossmember, ect.) but I didn't expect to run into this, I figured the 700 had a normal speedo cable that would work on the th350. Can anyone help?
Old 09-30-2003, 10:11 PM
Crosley's Avatar
Wiki Edits: 1659
Cool
I think you will find what you need at this site:
http://www.jagsthatrun.com/Pages/Spe...eedometer.html
