92 black rose - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2012, 01:57 PM
92 black rose
Hay guy's dose anyone know if I take all the smog off my 92vette will it turn a check eng lite on and will the car run right thank's guy's
Old 02-20-2012, 05:49 PM
LATECH's Avatar
For every action, there is an equal and opposite Re action, so to put it short YES.
Leave the emmisions devices intact.
Depending on the devices and how they are altered some systems may mildly affect performance, some may pretty drastically effect it.
Disconnecting an EGR will cause part throttle detonation at cruise speeds, which can damage your engine.
Disabling the evaporative system will not effect performance noticeably, but will stink up your garage with fumes.
Catalytic converters are pretty much non restrictive, unless damaged by neglecting maintenance, or altering emmisions devices.
On a 92 most anything else that hasnt been mentioned will add performance , like port injection electronic timing control.FYI
Old 02-21-2012, 05:49 AM
Lt1 motor
I'm. Going two port the head's and put a lt4 cam in it and see if that help's the hp out any thank's guy's
Kustom Shop's black cherry kandy over black diamond metallic for dark reddish-black? 350cruiser Body - Exterior 3 08-03-2010 07:02 PM
black trim re paint questions, flat or gloss black? tiptopss Body - Exterior 5 04-11-2010 09:51 AM
bob and rose fulton bob and rosie fulton Introduce Yourself 3 09-11-2006 05:50 AM
poly bushes or rose joints blown volvo Transmission - Rearend 1 10-21-2005 04:56 PM
Nairb's Movie Capsule-the Exorcism Of Emily Rose NAIRB Off-Topic 2 10-01-2005 11:14 AM
