Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Thread Tools Search this Thread share on Facebook
  #1
Old 12-12-2011, 05:56 PM
Mr.Fixxit's Avatar
Mr.Fixxit Mr.Fixxit is offline
'92 Blazer getting no fuel :(
My brother has a '92 S10 Blazer 4.3 Vortec V6. Drove home from work today, ran fine according to him ( Plus I saw him drive in and seemed to be running fine ). He shut the truck off, and about 45 mins later he went to leave, it wouldn't start. It cranks and has spark. I've worked with cars for 15 years, but am still getting the grasp of fuel injection. Carbs are my specialty. I think it's the relay, because I don't hear that "click" or the whine of the fuel pump, or maybe a fuse? I could really use some help, thnx in advance.
Register now (free) or login to remove ads
Old 12-12-2011, 06:16 PM
LATECH's Avatar
LATECH LATECH is online now
Last journal entry: Tips
on the back of the motor where the fuel lines come in there is a fuel pressure test port. It will have a little black cap on it. Use it to check the fuel pressure. I dont have the spec for the pressure on hand, but if is too low the injectors wont spray.They are electronic injector solenoids with poppet style injectors. meaning even if the solenoid is turning on, the injector wont spray untill the pressure is high enough.
If there is no pressure then move on to checking the electrical system for its 2 second prime pulse from the ECM , then the OP switch circuit for maintaining pump voltage after start.Check for ANY pressure first.then go from there.
Old 12-12-2011, 06:44 PM
Richiehd's Avatar
Richiehd Richiehd is offline
JS-70
Sounds like fuel pump, common GM issue. Bang on the bottom of the tank while cycling the key on and off, Somtimes it will start and run, so you can get it in the shop or back to the house.
Old 12-12-2011, 06:52 PM
LATECH's Avatar
This post has been moved to the Modern Engine Electronics section.
Old 12-13-2011, 06:10 AM
alkey alkey is offline
92 blazer no fuel
if i remember correctly on that vehicle the fuel pump relay and ac relay are the same part number.if your blazer has ac you can switch relays to see if relay is problem.most likley fuel pump.Good Luck
Back to top
Recent Modern Electronic Engines posts with photos
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "'92 Blazer getting no fuel :("
ThreadThread StarterForumRepliesLast Post
01 Blazer fuel pumpbbussElectrical606-03-2011 08:58 PM
96 blazer fuel pumpricksautorestorationEngine1506-07-2009 02:16 PM
1996 blazer fuel issuesbrian berwickEngine108-18-2008 04:04 AM
1997 Blazer 4.3L V6 L35 Fuel Injectionmonette999Engine802-25-2008 06:43 PM
v8 blazermurry42Engine106-20-2004 10:16 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
