92 Bonneville no power - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2009, 01:05 PM
i have a 92 bonniville se 3.8 liter the car ran fine then i parked it for a year n the battery froze so there was no power at all so i got it to start off a jumper box n it ran for 15 minutes then died n now no power again n i just replaced the alternator 2 years prior n the battery was just a year old i wondered if the battery warmed up would it start again or should i get anew battery
Old 02-02-2009, 03:43 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
you will just have to check if it is charging
if you dont have volt meter i think you could take the alt. off and take to any parts store and they will check for you
it wouldnt hurt to take the batt. with you also however to be checked correctly you need to try and charge it, if it will take one
Old 02-02-2009, 06:03 PM
302 Z28's Avatar
Moderators note: Welcome to the group . In the future please title your posts with a subject line. It makes future searches far easier when someone is looking for information.
Thanks
Vince
Old 02-02-2009, 06:20 PM
T-bucket23's Avatar
Wiki Edits: 26
Once a battery freezes it is usually junk.
Does it have power if you put the jumper box back on it.
Those also have a ground block down onder the rug by the drivers side kick pannel. It is a real lousy setup and will make the car die, not start and other weird things. It is basically a connector with a bunch of spade connectors and it has a piece of metal that caoonects all teh spade connectors. They corrode and cause issues. I have fixed many of there in mid 90's GM vehicles.
Chet
DARK brown--BLACK plugs SBC Joshua Lee Engine 128 02-03-2008 09:12 AM
chevy 350 jimang22 Engine 4 07-14-2007 03:49 PM
Pully problems: sbc 671 weiand, power steering malibu68 Engine 1 12-05-2006 10:09 AM
Advise on Porta Power choice meanroy Body - Exterior 7 06-23-2004 11:38 PM
Unusual Power Steering Conversion Lars Sorensen Suspension - Brakes - Steering 17 05-25-2004 02:05 PM
