92 Buick power rack pinion using 68 Ford pump? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2002, 07:54 AM
New Member
Post 92 Buick power rack pinion using 68 Ford pump?
Does anyone see a problem with using the 68 Ford power steering pump with the 92 Buick power rack pinion steering. I understand having to have the lines made up. I was more worried about a pressure problem(not enough/to much). Thanks, Jay
Old 09-14-2002, 08:40 AM
aka Duke of URL
Arrow
I see no problem, but if pressure worries you (shimmy in steering wheel while turning/blown rack outlet seals) get the specs from each makers shop manual and put an adjustible regulator in the pressure line.
Old 09-14-2002, 11:21 AM
New Member
Post
Thanks for the reply Kultulz. My brother-in-law also didn't see any problem so I am going to give it a shot. Later, Jay
