92 Camaro Starting Issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-11-2008, 08:09 PM
Last journal entry: new bracket for the ev-100 controller
I HAVE 92 CAMARO WITH A STARTING PROBLEMS, 9 OUT 10 TIMES IT JUST CLICKS WHEN I TRY TO START. REPLACE STEERING COLUMN SWITCH ,CABLES,STARTER,BATTERY. I HAVE CHECK THE FLYWHEEL TEETH. IF I TURN THE CRANKSHAFT BY HAND JUST A FEW INCHS IT USUALLY STARTS. ANY IDEAS...
Old 12-13-2008, 01:26 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Is the starter drive gear sticking to the flywheel. You can prolly hear the clack of the starter gear retracting into the starter as soon as you move the crank.
IF it is sticking, you'll need to check you flywheel to drive gear clearance.
Otherwise I might blame the starter soleniod. It houses the switch that turn on teh motor a fracation of a second after the gear extendsto mesh with the flywheel.
1967 Camaro Starting Failure colincamaro Engine 2 01-20-2007 03:29 PM
dual batteries for starting darom Electrical 25 01-14-2007 06:06 PM
Major starting issues are stressin me out! Dizturbed One Electrical 1 10-17-2006 11:38 PM
69 Camaro - few questions stratt134 Suspension - Brakes - Steering 4 07-21-2006 08:50 PM
68 Camaro Starting Problem jctrayer Electrical 5 10-27-2003 01:12 PM
