-   Introduce Yourself (http://www.hotrodders.com/forum/introduce-yourself/)
-   -   92 chevy 1500 (http://www.hotrodders.com/forum/92-chevy-1500-a-199772.html)
94355sonoma 06-03-2011 08:38 PM
92 chevy 1500
i have a 1992 chevy 1500,has a new motor its a 350 with a small cam 0.458"/0.461".i just installed tbi with the electronic distributor so im running the stock ecm.so far it seems to be running ok but when i drop it in gear it wants to stall i can feather the throttle and after a couple of seconds it will idle on it own just fine,also it breaks up from a dead stop when you step in it hard,only breaks up for a second then it fine.plugs,wires,cap,and rotor all new.fuel pressure is good.im thinking maybe distributor.the one i used had been sitting for a long time,had a little surface rust but i cleaned it up thought it would be ok maybe not.any advise guys,also has anyone used the jet chips from summit i thought it might help my problem
eloc431962 06-04-2011 11:06 AM
Welcome to the site.
Cole :pimp:
