92 chevy 1500 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 06-03-2011, 08:38 PM
92 chevy 1500
i have a 1992 chevy 1500,has a new motor its a 350 with a small cam 0.458"/0.461".i just installed tbi with the electronic distributor so im running the stock ecm.so far it seems to be running ok but when i drop it in gear it wants to stall i can feather the throttle and after a couple of seconds it will idle on it own just fine,also it breaks up from a dead stop when you step in it hard,only breaks up for a second then it fine.plugs,wires,cap,and rotor all new.fuel pressure is good.im thinking maybe distributor.the one i used had been sitting for a long time,had a little surface rust but i cleaned it up thought it would be ok maybe not.any advise guys,also has anyone used the jet chips from summit i thought it might help my problem
Old 06-04-2011, 11:06 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Welcome to the site.
Cole
98 Chevy 1500 350 vortec dougm72 Engine 4 02-02-2011 12:18 PM
chevy 1500 4x4 trans into a 4x2 hellraiser509 Transmission - Rearend 4 12-30-2009 11:27 AM
1995 chevy 1500 SonnyFaust Transmission - Rearend 9 12-26-2008 10:17 PM
02 chevy 1500 4x4 v6 to v8 swap mike1975hd Introduce Yourself 2 10-15-2008 10:02 PM
350 in a '91 1500 chevy truck. bbogler Engine 0 09-18-2002 07:07 PM
