92 chevy 350 problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2013, 05:38 PM
I have a 92 chevy with a 350 with a problem it has good throttle response but when its under load it has a hesatation like its not hitting on all cylinders any thoughts?
Old 03-12-2013, 10:16 PM
DoubleVision's Avatar
My father's 98 GMC was doing the same thing not too long ago. I'd floor it and it would bog down and pop. About 2 weeks after it started the fuel pump went out, which was what I suspected it was to start with. First off, check the fuel pressure. Second, what shape is the tune up in? When was the last time it had new plugs and plug wires? Have you checked it for vacuum leaks?
The Following User Says Thank You to DoubleVision For This Useful Post:
1Gary (03-12-2013)
Old 03-13-2013, 02:07 PM
I would second that, if it hasn't had a tune up for some time it would not be like throwing money away to first start with the basics that wear out over time. Delco spark plugs & wires, most likely a cap and rotor, again stock Delco ( is your unit the coil in cap style or a stand alone coil ? ) , also a fuel filter. Then check the timing just to make sure its still on TDC with the connector unplugged after the tune up. Do those and then evaluate how its running.
If you decide on the tuneup, I like to have had the engine shut down from a good run down the highway so it shows a better read on the plugs ( let the engine cool where you intend to do the work on the truck ), also when you take out the plugs it would be a good idea to mark where each plug/cylinder it came from ( you can use some masking tape and write the number on it and wrap it around the insulator ). That way if there is a surprise as your pulling the plugs you can know for sure which cylinder it came from.
Old 03-13-2013, 05:10 PM
LATECH's Avatar
X 3 with all the suggestions here. Maintnance Items need to be adressed first before attempting to diagnose.
Tune up and fuel filter etc... need to be checked and replaced if needed.If your not sure when you look...replace it.Or get a second opinion.
Could be a bad valve spring or valve sticking in guide .
Fact is stranger than Fiction
Old 03-13-2013, 05:45 PM
I forgot to add that during a tuneup when all the plugs are out, thats the perfect time to do a compression test of all cylinders assuming you have or can get access to a decent gauge and are familiar with the procedure or get a run down on that in the forum so you don't fry the ignition system etc. While it may not reveal anything, it also may and will give a somewhat general idea of the health of the engine and not have to back track and pull plugs all over again to do the test after the fact. I find using a good charger on the battery or a booster battery helpful to keep things consistent through a test like that. Then if you come across a cylinder that is way lower, you can do a wet test on it to see its reaction and so on.
fuel problems chevy 350 aarias-31 Engine 6 08-12-2011 10:56 AM
chevy 350 timing problems Wildwestshow Engine 5 09-24-2010 04:54 PM
Cooling Problems 350 Chevy LunchBox2552 Engine 7 12-18-2009 02:16 PM
help please chevy 350 problems wickedenvy Hotrodding Basics 14 08-15-2006 09:23 AM
chevy 350 problems Thacolbster Engine 9 01-05-2003 03:15 PM
