92 Chevy S10 Fender swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-04-2009, 11:54 AM
Hi guys,
A friend of mine got a lil S10 truck for his son. Both front fenders are rusted badly and he got a set a new ones. Now he is trying to swap them out but not exactly sure what all needs to be done in order to do so.
He got a repair manual but he is saying it doesn't tell.
Any help would be greatly appreciated!
Tomi
Old 11-04-2009, 07:57 PM
Countilaw's Avatar
Cox Custom Cars
Look at the new fenders and locate the bolt holes. Then look at the truck and find the same bolt holes and start removing the bolts. There should be one bolt at the bottom under the doors, one at the top next to the doors, two on top of the radiator support, and several down the upper edge of the fender along the hood line that connects the fender to the inner fender. There will be two under the front of the fenders connectting them to the valence.
Frank Cox
Cox Custom Cars
Rio Vista, Tx
Old 12-12-2009, 11:55 PM
Rix-Trix's Avatar
Last journal entry: Box is back on the truck
Don't forget the two inside the door.
Old 12-13-2009, 01:01 AM
Let's not forget the bolts for the inner fender located in the wheel wells. 10mm and 8mm sockets should cover it.
Old 12-14-2009, 01:25 PM
S10xGN's Avatar
Gotta love a turbo!
Jump right in, it's not hard at all. I've had the complete front clip off my '96 piece by piece in less than 45 minutes.
Russ
Old 12-14-2009, 02:27 PM
Thanks guys for all the advice.
I jumped on it a lil while ago. I took my buddy quite a while buy he got it all done!
Greetings Tomi
S10 v8 swap hearders eric32 Engine 12 01-25-2010 08:22 PM
56 Chevy BelAir rear end swap or not? Tymer Transmission - Rearend 5 11-23-2008 10:21 AM
Ford Flathead Chevy S10 Transmission Swap tommy98466 Transmission - Rearend 4 08-01-2008 07:38 AM
1953 chevy frame swap Bwagner General Rodding Tech 3 07-01-2004 09:35 AM
S10 V8 Swap Thuggishruggish3000 Engine 1 08-04-2003 12:00 AM
