92 dakota and me not gonna have hair left - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
  #16 (permalink)
Old 03-04-2013, 12:23 PM
Last wiki edit: Hand cleaner Last photo:
Wiki Edits: 3
for what ever reason the books on MOPAR have a number of things that aren't right, and with bad info it can cause problems when trying to trouble shoot.
as LATECH said, the ASD relay also powers the fuel pump & the 2 second power up primes the fuel system.
the 2 second power up at the ignition coil is normal.
some will even give 1 ignition pulse at key on which can be quite a surprise if you happen to have the ignition coil wire off & are too close to the terminal when the key gets turned on.
with a decent scanner, there are a number of tests you can do that can be very helpful in trouble shooting such as triggering the ADS relay, injectors & ignition coil key on engine off.
i used a MT2500 for years which you can pickup now for cheap.
a good one may not be a bad investment.
just don't use a MT2500 trying to repair MOPAR ABS.
another problem i ran into with some MOPARs is using aftermarket sensors. i spent 2 days diagnosing a no start on a mini van caused by the A/M crank sensor we put in as a preventative measure during a trans O/H.
Recent Modern Electronic Engines posts with photos
Evercoats: Fiber Tech, Everglass, Kitty Hair, Tiger Hair, Metal to Metal rusty428cj Body - Exterior 5 02-12-2013 02:49 PM
Kitty hair ? 92redgt Body - Exterior 4 11-18-2006 08:04 AM
Help!! - 3.7 volts at coil pos.(no hair left..) dabongo Electrical 1 09-07-2006 04:47 PM
hair style 406chevelle Off-Topic 4 06-10-2006 12:01 AM
Pulling my hair out! cool rockin daddy Body - Exterior 3 04-14-2006 02:53 PM
