Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 92 dodge dakota converted to carb alternator help
Old 12-03-2012, 01:18 PM
Pont.72lemans Pont.72lemans is offline
Pontiac Muscle Gearhead
i converted my 92 dakota to carbureted and have everything set up i have driven it and everything is fine, except for the alternator will not charge the battery and the alternator itself is good, the problem is that it is ran through the computer and i need your help on how i can set it up to run without the computer and function fine .. i based the ignition system off of a 78 dodge magnum and so i have that distributor ICM and resistor. how can i wire the alternator, what regulator should i get, any and all advice diagrams or input is needed i need to have it on the road this week to store my 72 pontiac for the winter
