Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 92 dodge dakota converted to carb alternator help
Old 12-03-2012, 02:51 PM
vicrod's Avatar
vicrod vicrod is offline
life is a ride
Last journal entry: 2014
internal
According to the Autozone repair help website this alternator has an internal regulator.
The initial field signal is sent through the charge light on the instrument panel. If this charge light/circuit is not working the alternator won't work. The light should be ON when ignition is turned ON and go OFF after the engine is running.
Check to see if the charge bulb is good.
The computer is for monitoring only and should not affect the operation/charging.
vicrod
