92 Dodge Dakota won't run in 3rd gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2010, 08:21 PM
My 92 dakota has a 3 spd automatic with OD. It will not run in 3rd gear just slips whether in drive or shifting manually. In drive as well as manual runs fine in 1st and 2nd but slips in 3rd.. I obviously don't know much about transmissions. I did check the fluid level was ok but smell a little burnt. I just want to know if this is a major repair (Tranny replace or overhaul)or if possible just a minor repair( Solenoids or Valve body repair?)
Old 11-09-2010, 04:48 AM
tnsmith10's Avatar
when will it rain???
how many miles are on the transmission? has it had any service or repair work recently? any leaks coming from the trans to cause a low fluid condition that could cause a slip?
for this year trans, it only has 2 solenoids, 1 for the torque converter clutch (lockup) and the other is for overdrive, the first 3 gears are still hydraulic like the old torqueflites.
the direct drum is for 3rd gear, and theres not much you can do except pull the trans and get it rebuilt. you have already mentioned the fluid is burnt, and with an internal problem, a rebuild would be the best course of action.
Old 11-09-2010, 07:30 PM
127,000 miles. No repairs recently that I know of. Didn't find any leaks. Any idea of the cost to rebuild? Thanks for your reply. I really appreciate it.
602 fitter
1992 Dodge Dakota stops shifting into third gear after transmission warms up loladavis Transmission - Rearend 3 08-24-2010 05:13 AM
Anyone run a Pete jackson noisy gear drive in a sbc? batman09 Engine 60 01-24-2006 01:17 AM
T-56 NO MORE 4TH GEAR, and NO 3RD GEAR SYNCOS!!! chevyelc81 Transmission - Rearend 5 12-05-2004 10:39 AM
lost 3rd gear on th 350 Hot_Rod_Faith Transmission - Rearend 13 12-28-2003 12:39 PM
tranny slipping 3rd gear..... 73monte Transmission - Rearend 1 12-20-2003 02:22 PM
