Could be a shift solenoid problem Have you driven and then scanned for codes? It should throw something your way.
Trans control box???? what the ?? Are you trying to manipulate shift with a scanner? external controller? Where is the PCM in all of this?
Fact is stranger than Fiction |
Could also be Intermediate/OD band is not applying. Stuck servo (piston) /missing servo(piston) seal
Well, 2nd gear and O-Drive in the trans are both clutch packs not bands.
I suggest you inspect the clutch packs for proper clearance. What was the original failure? Why was the separator plate replaced? What was used as replacement? The bind up in reverse indicates something is applied that should not be. Was the accumilator v-body section replaced or rebuilt or not? Was the solenoid body replaced or not?
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Not sure about original failure because of an engine issue that wouldn't let us drive it. The student wanted to overhaul the trans mostly for the experience.
The spacer plate was replaced because when we first started diagnosing the problem after the overhaul I had him take the valve body off and check for proper check ball location and valve body assembly. We found that one of the filters in the spacer plate was on the wrong side and dented it when valve body was tightened. I thought "there is our problem, and this is a good learning experience". We replaced spacer and gaskets with OEM parts. Same shifting problem. We now have the trans back out and disassembled thinking we would find something burnt or possible incorrect assembly etc. but we find nothing wrong. The valve body and solenoid body were only cleaned up and re-used. Thanks again, Rick |
| 460 into 1979 F150 4x4 | Alaskanpowerstroke | Engine | 6 | 11-01-2011 08:10 PM |
| my 1979 f150 short bed 4x4 | fordisbetter | Introduce Yourself | 4 | 04-15-2008 03:31 AM |
| 1995 chevy s10 blazer 4x4 v6 trans problems | SonnyFaust | Transmission - Rearend | 7 | 11-27-2007 06:56 AM |
| 4x4 1994 Trans problems ???? | sinlow1980 | Transmission - Rearend | 2 | 07-16-2007 06:37 PM |
| ABS module problem on a 97 F150 4x4 | jmhollis | Suspension - Brakes - Steering | 1 | 09-03-2005 09:53 PM |
