92 ford ranger motor,tranny & rear end swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-24-2009, 10:59 AM
I currently have a 2.3 liter ford cylinder 5 speed tranny, and 3.55 rear end gears. I want to swap to a 289 engine. What do you recommend to use as a tranny and rear end? thank you for the help!!
Old 07-24-2009, 11:10 AM
Wiki Edits: 31
8.8" rear end from an Explorer or Ranger 4.0L ( bolt in ).. whatever trans you have will do, but if you want to keep the 5spd, you'll find the 2WD manual transmission from a late 80's, early 90's F-150 will bolt in with no modification, except I belive the tailshaft is longer so you'll need a shortened driveshaft... others use the T5 from vehicles like Mustangs, but they take a little more work
Old 07-24-2009, 03:05 PM
techinspector1's Avatar
Wiki Edits: 326
Have you considered a turbo swap from a Thunderbird Turbo Coupe?
Old 07-25-2009, 07:20 PM
Thats a very good option. A 302 would be good too and they are cheap to get ahold of. Even cheaper than a SBC. Ive seen so many 302s on craigslist for 100-150 lately it makes me wish i had some money.
56 Chevy BelAir rear end swap or not? Tymer Transmission - Rearend 5 11-23-2008 09:21 AM
Ford 9" rear end wildfire78 Transmission - Rearend 4 10-20-2008 08:08 AM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 03:28 AM
1946 ford Truck Rear End HELP Jim1926 Transmission - Rearend 1 11-29-2005 02:50 PM
Ford Pickup Rear End Kaylah Transmission - Rearend 6 05-09-2003 03:14 PM
