92 G20 van rear end... Givin it all i got to get it out - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-30-2012, 08:10 PM
chevy302builder18's Avatar
mr mighty mouse
Last journal entry: shes dropped!!
ok got the van on jack stands, one tire off and ive got one leaf spring nut off.. The bolt is still in the frame and leaf shackle. Its the back shackle. I came here to ask, (first time thing) how you guys get rear ends out.
Old 03-30-2012, 08:14 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
to get stubborn u-bolts
you may need to get out a big breaker bar with a pipe on the handle for an extension
or just cut them with a torch or sawsall
Old 03-30-2012, 08:16 PM
mr mighty mouse
ok forgot to mention the bolt is stuck in the shackle and the frame. Im giving it all i got. I got the shocks off too.
Old 03-30-2012, 08:17 PM
chevy302builder18,
Pry bars, BIG hammers, floor jack and a come-a-long and maybe a few CHOICE WORDS. And if these do not do the trick then I WILL use the Victor wrench!
Scholman
Old 03-30-2012, 08:18 PM
mr mighty mouse
ok well i gotta grinder. Its shall work. I want these springs for my 78 PU theres five opposed to the 3 on the 78. Guess what?. Just got my truck!!!
Old 03-30-2012, 08:21 PM
mr mighty mouse
Originally Posted by scholman
chevy302builder18,
Scholman
used a huge sludge on the shackle bolt, it aint budging. Whats a victor wrench?
Old 03-30-2012, 09:40 PM
mr mighty mouse
well i got her. Thanks for the quick replys. One sides out. Still want those 5 leafs, but those arent budging
Old 03-30-2012, 10:14 PM
Wiki Edits: 31
Victor wrench is a torch. also known as a hot wrench.. When I have to pull a rear end, torch is what I use if I can. U bolts should be replaced every time so theres no reason not to, as it wont damage the springs. At the junkyard, I use a cheater bar and hope they break quick..
If this is the same van that's getting scrapped. I'd just cut the hangers off with a sawsall or a torch.
Old 03-31-2012, 03:11 AM
mr mighty mouse
yup sure getting scraped. i dont gotta torch to cut but i gotta grinder. thinking itll be a lil more time with grinding the hangers and stuff. planning this out ill have to save some mullah for the U bolts and dont get me wrong... im broke. but sure be fun addition to the rod. its a semi floater 3.42 gears. sure make a good add for the rod.
Welding a rear brace on a ford 9 inch rear end makaveli200369 Transmission - Rearend 4 07-02-2009 10:19 AM
351 Modified Givin me trouble d_erickson Engine 2 03-17-2007 03:26 AM
1/2 tonn burb rear and 1/2 tonna blazer rear.. u joint? boneyard Buick Transmission - Rearend 1 10-08-2006 11:46 PM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 03:28 AM
67ssdiagram showing how the rear sway bar and control arms connect to frame and rear DeathByGreaser Transmission - Rearend 0 02-08-2003 08:10 PM
