'92 S10 Rear Drum Backing Plates - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-23-2007, 07:48 PM
I have a '92 S10 Blazer 4wd differential housing and wanting to keep the rear drum brakes I bought all new components including axles, seals, bearings, brakes, drums, wheel cylinders, hardware and etc. However, when it came to the backing plates the only thing I could find were the thin aftermarket two bolt type for the clip retained wheel cylinder. I want the backing plates that require four bolts to attach the plate to the axle housing, two bolts to attach the wheel cylinder and can't seem to locate them. My friendly Chevy dealer told me that they were discontinued and not available. I really don't want to incur the $ of converting to rear disc brakes at this time due to budget restraints and the amount of $ that I have apportioned to other phases of my rebuild. I'm preparing an S10 chassis to go under my '54 Chevy pickup. Where can I get the correct backing plates or what other options are available to me? Thanks to all who take time to give me some suggestions.
Old 11-25-2007, 01:28 PM
runn141's Avatar
78-87 g body are the same, im guessing 82 and up camaro are too.
Road and Race S10 Rear Suspension mgray Suspension - Brakes - Steering 13 04-12-2005 10:51 AM
50 pontiac coupe want to use a s10 front clip and rear will these work thanks JOHNNY M BROWN Suspension - Brakes - Steering 5 11-27-2004 08:12 PM
Where to buy a new rear for my s10 96s10 Transmission - Rearend 1 01-20-2004 12:54 PM
s10 rear end rpo codes S10lady36 Transmission - Rearend 2 10-14-2003 09:20 AM
Rear End width for V8 S10 s10V8-357 Transmission - Rearend 0 10-08-2003 05:52 PM
