92 SBC 5.7 flexplate/Torque convertor - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2005, 08:10 AM
I'm accumulating parts for a project 64 Van V-8 conversion and was wondering if the Flexplate for a 92 5.7 Chevy will bolt up to the torque convertor on a Turbo 350 that currenty is on a 78 250 -6 I don't know the compatability between the 2 if the bolt pattern is the same as the flexplate I'm sure someone makes one with holes that do work, a little more universal pattern any help greatly appreciated. Thanks, Eric
Old 03-23-2005, 05:11 PM
The 92 moter and the converter for the T350 both use the 12" diameter torque converter bolt holes. 168tooth and 153 toth flywheels have these holes.
92 SBC intake mounting Eric64 Engine 3 03-18-2005 03:08 PM
92 5.7 options Eric64 Engine 3 03-05-2005 06:08 AM
help please with SBC thorque convertor leastbay Transmission - Rearend 4 09-19-2004 11:45 AM
how much can sbc stock 5.7 rods handle? sb72elcamino350 Engine 15 04-25-2004 11:42 PM
powerband sbc 350..6" rod vrs 5.7 rod Dave Y. Engine 1 11-08-2002 08:01 AM
