Thread Tools Search this Thread share on Facebook
  #1
Old 04-24-2009, 05:21 PM
Eric64 Eric64 is offline
92 SBC intake gaskets
I just picked up a new gasket set Felpro and I'm sure someone a whole lot smater than me can answer. On the 2 rear water cooling ports (L&R) the gasket is almost solid except there is about a 3/16-1/4 in. hole. I'm assuming that is restricting the water flow to make it go the proper way or hold it in the block longer. Bottom line I'm just curious as to the purpose and reasoning. Thanks, Eric
Register now (free) or login to remove ads
Old 04-24-2009, 05:27 PM
carsavvycook's Avatar
carsavvycook carsavvycook is offline
My 2 cents worth
Wiki Edits: 3
You should have a heater port on the right rear corner of your manifold. These gaskets are designed to bleed air, and push the hot coolant into the heater core, instead of back through the engine block.
Old 04-24-2009, 05:38 PM
fast68's Avatar
fast68 fast68 is offline
likes chevy trucks & boobies
heater core hose port*
Old 04-24-2009, 08:50 PM
Thank you, I sure could't figure how that was going to cool the block
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "92 SBC intake gaskets"
ThreadThread StarterForumRepliesLast Post
Question on Pro Comp Heads on SBC and intake matchingy2k600f4Engine1909-29-2008 05:55 AM
Removing intake on SBC... help!v8hedEngine1406-06-2008 04:35 PM
SBC intake boltsCape Cod BobEngine305-27-2008 06:36 AM
SBC 283 intake & Carb Swap Problemsiceman_77Engine402-13-2007 05:49 PM
Intake gasketsMHenricksEngine002-08-2003 06:26 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
