92 SBC intake mounting - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2005, 12:57 PM
I have a 92 5.7 out of a truck without a manifold I'm putting it in a 64 chevy van, It's at the machine shop being freshened up right now. What I'm needing to find out is I know if I find a TBI/TPI I can install them however If I go the carb/HEI setup can you modify an earlier intake by slotting the heat riser mounts to match up the angle on the heads or do I need to buy an intake just for that, Expense wise I'd like to avoid that any thoughts or suggestions appreciated, obviously it's not going to be a racer just want a fun vehicle. Thanks, Eric
Old 03-18-2005, 01:18 PM
from my research you can just slot it, but someone here will know for sure.
Old 03-18-2005, 02:48 PM
GoneNova/406's Avatar
you should have gotten a block off kit in your gasket set.just block it off especially if you live where its warm all the time.i live in the cold and don't hhave any on my heads and don't use them and don't have any problem.
Old 03-18-2005, 03:08 PM
NorthStar's Avatar
You can buy an Edelbrock Performer or a cast iron GM manifold to convert to carb if you dont want to grind on intake.
Im not 100% sure about there being a GM manifold but there must be one made for marine applications.
GM fast burn heads batman09 Engine 1 10-26-2004 09:32 AM
SBC head intake runner size CC's Sagacious Engine 2 10-22-2004 06:44 PM
SBC Advice frydz1985 Engine 8 10-10-2004 12:34 PM
sbc 6 - 2 barrel intake on ebay crshrmn3 Hotrodders' Lounge 0 09-09-2003 10:20 AM
adapting early sbc intake manifold to 1987 350 heads steve curtis Engine 1 06-13-2002 02:56 AM
