Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 92 silverado tbi problems
Old 02-03-2011, 12:49 PM
sqzbox's Avatar
sqzbox sqzbox is offline
My pipes are my music
Originally Posted by brandon meek
i to own 92 chevy tbi 350 that would bang out,back fire at high rpm 3500 and up worse when cold u could ease it up and would do better no codes replace throttle body was distributor reluctor ring loose fixed right up
He sed it been fixed, up all rdy but didnt say what wuz wrong egr or coil main thing is he got it going i had problem, with coil wires touching each other once and by luck found arcing between them separated wires and problem with misfire and hesitation, went away i guess wires wore down from constant rubbing together on, the, external, coil
