92 truck block - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-12-2006, 02:57 PM
92 truck block
heyfolks,been lurking around for awhile finally joined up. I'm getting ready to build my first stroker motor.I've acquired a 92 350 truck block.The block has the threaded studs down the middle of the lifter valley.I'm trying to find out for sure if I can use a roller cam in this block.I have read several articles in Chevy High Performance mag about the GM Performance hot roller cam.I would be using their roller hot cam kit and lifter and retainer kit this is the reason iam trying to find out about the block.The locally chevy dealer parts guy just said "yeah" alot when I asked him about the block nothing really positive.I've looked at some threads on here and heard several different thingsabout the block sort of a maybe,maybe not deal.Right now the block has flat tappet lifters in it and thats all i know I can't get to it right now because my friends shop has collapsed on it due to Katrina. I have many,many more questions to ask. Thought this would be a good place to start. thanks 85 chevy
Old 01-12-2006, 03:26 PM
406 ss monte's Avatar
eat a beaver, save a tree
that should be a roller block. does the front of the cam bore have the retainer plate or the holes for it? you can get the spider & lifters off ebay for cheap.
Filling Block/ Hard Block??? camaroman7d Engine 8 01-15-2004 07:30 AM
need info on small block chevys engine-rookie Engine 1 05-03-2003 08:48 PM
4 Bolt Block HotRodS10 Engine 16 05-21-2002 06:27 PM
66 ford truck swapping a 240 i6 out for small block chevy igotachevyor2 Engine 0 04-14-2002 03:19 PM
