93 350LT1 engine Build - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2012, 05:00 PM
Ok guys, I'm back with another problem that I hope someone can answer. I bought a 93 model LT1 shortblock .do I have to have a reverse flow intake and heads. is this true?
Old 03-02-2012, 05:39 PM
RippinRon's Avatar
Yes. The intake has a bolt pattern unique to itself and the LT4. And the block and heads are reverse cooled and again will not interchange with traditional sbc's.
Old 03-02-2012, 05:52 PM
Yes you have to use reverse flow heads and intake. The LT1 and 4 have coolant flow passages where normal flow blocks and heads have an oil return. Using standard heads on a reverse flow block will result in a massive coolant leak into the oily parts of the engine.
However, reverse flow heads can be modified to run a standard block by welding the unique coolant passages closed, this is possible because these heads are aluminum. This still takes making an external coolant return on the ends of the heads as there is no connection on the manifold face to return coolant to a route as part of the intake. This can be built, but it is very difficult fabrication and then welding of several small detail parts to form a passage. Of course after all this welding the heads have to be re machined.
Cast iron doesn't take to being welded without the use of expensive heating till the whole block is dull red. Then welding in plugs, allowing it to cool at a controlled rate for a day or two, then magna-fluxing to see if you got lucky and it didn't crack. When done, the block is warped and needs to be completely re-machined. It's easier to find some LT1/4 heads on
Ebay, or sell the block and get something that works without all the difficulties and complication.
As you can see I haven't got to the intake as, I'm sure you can see, there is no point.
Bogie
Old 03-03-2012, 01:40 PM
Thanks Bogie, I have a 93 regular engine out of a truck.I'll just use it being I already spent $600.00 on a set of alum. heads that wont work on the LT1.Well back to the drawing board.Sure glad you smart guys tolerate dummys like me.
Thanks again Bogie,probably be back for more input before I get this other engine built. HA !
70'Monte Carlo project 350LT1 swop ElGordito01 Engine 1 01-26-2012 12:16 PM
350lt1 foster2z28 Engine 5 11-18-2011 11:15 AM
Which engine to build? nikwho Hotrodding Basics 6 02-23-2011 06:07 PM
first engine build 86 iroc Engine 19 03-08-2010 09:04 PM
engine build up Frank50 Engine 2 02-15-2003 01:32 PM
