93 4.3 swap to 95 5.7 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2013, 06:34 PM
I have a 93 c1500 with a 4.3tbi v-6 and a 4l60e transmission. I would like to put this 95 5.7tbi with the 4l60e; I have the 95 computer & computer. Will 4.3 flywheel, fuel pump & wiring harness work. Also what else....
Old 03-23-2013, 07:29 PM
radical
What performance upgrades would get me to 300hp without machine work?
Old 03-24-2013, 06:39 AM
bondo's Avatar
Nope,... The Flywheel is different, 'n the wirin' harness will be too short...
Old 03-24-2013, 10:27 AM
Thanks I Know I need different radiator & fuel pump. I want to add throttle body spacer, roller rockers, headers & upgrade 02 sensor. What kind of set up do I need in the ecu? And what else can I do for better street proformance?
Old 03-24-2013, 11:27 AM
LATECH's Avatar
Headers would be the only upgrade that will give any performance upgrade.Roller rockers are a waste of money.
New O2 sensors are fine, as they are a maintenance item.
Fuel pump is the same as it is intank. Leave it be for now, Dont mess with the fuel pressure ....yet.
Throttle body spacer.....meh.$$$$$
Fact is stranger than Fiction
Old 03-24-2013, 01:15 PM
5.7
I think I responded to your other thread regarding this. Headers are about the only bolt on upgrade you can do. and that will not get you close to 300 hp. If you want to get in that vicinity I'd recommend going to an LS1 or LT1 engine. That would net you near 300 hp. Otherwise...you'll have to tear down that 350 and do some internal alterations to get anywhere near 300 hp
Old 03-24-2013, 06:58 PM
also hottrodding basics
thanks for info I will reply again when I tear into the 5.7 or get a crate motor!
LS1 Carb Swap and Cam Swap. Hacksaw Engine 27 12-15-2013 09:40 PM
suspension swap or frame swap? mouse57 Suspension - Brakes - Steering 16 07-24-2013 07:29 PM
456 gear swap to 373 in 8.5 rearend, carrier swap? leslie61 Transmission - Rearend 3 07-19-2009 04:45 PM
Tranny swap/ rearend swap? aggar Transmission - Rearend 2 03-16-2008 04:07 PM
86 K10 engine swap! swap tranny too? big_e111 Transmission - Rearend 3 08-03-2007 02:21 PM
