93 4L60e stuck in second gear. - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-11-2012, 07:37 PM
GMCTRUCKS's Avatar
My 93 GMC truck 4L60e stays in second gear now it will go into reverse but it won't go into any other gear where do I start no check engine light on?
From a dead start it's taking off in second gear also here is some history on it for years my reverse has had a slight slip and it gets worst on hot Texas days also while gunning it while stuck in second it doesn't slip. I hope it's something small.
Thanks! RS
Old 04-11-2012, 08:48 PM
Check the fuse, it sounds like your not getting power to the tranny. If the fuse is okay you need to go underneath and make sure you've got 12 volts to the tranny. It's possible that the loom has worn thru and that the wires are damaged where they contact the back of themotor.
Old 04-11-2012, 10:59 PM
GMCTRUCKS's Avatar
Pete where is the fuse located I know beans about these Transmissions?
1993 F/S GMC truck. Thanks! RS
Old 04-12-2012, 10:50 AM
On my 94 its below the lefthand side of the fusebox. Should be labeled trans.
Old 04-12-2012, 12:47 PM
GMCTRUCKS's Avatar
Well I drove it a while ago and it was stuck in drive so I see my doctor and I came out and it started shifting fine but today my buddy is going to put his Snap-On scanner on it and see if anything comes up.
Im thinking of taking it to this Trans shop and seeing if he thinks the shift solenoid's should be changed out in fact I called before I drove it today and he said it sounds like one of them is bad he said the cost will be at the most $150.00 dollars which I think is worth it because im taking a 6 hour trip towards the end of the month.
Old 04-13-2012, 02:53 AM
GMCTRUCKS's Avatar
OK I found out that's it's B shift solenoid that's bad.
Thanks! RS
how do you remove a partially stuck valve in a 4L60e valvebody? old yukon Transmission - Rearend 7 01-31-2011 10:17 AM
4L60e low-reverse clutch retaining clip stuck! old yukon Transmission - Rearend 5 01-25-2011 10:39 AM
1998 4L60E stuck in second gear dlevi2121 Transmission - Rearend 4 05-15-2009 06:27 PM
Stuck in gear 86078 Transmission - Rearend 7 02-21-2006 04:42 PM
Stuck in gear!! (4SPD) Trav Transmission - Rearend 3 09-29-2003 10:52 AM
