93-94 s-10 rear in my NOVA - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2008, 07:23 AM
Sagacious's Avatar
Do you feel like we do?
ive decided to mini tub my nova and ive found that the wheel base i need happens to be the dimensions of a 93-94 s-10. the length of the housing should be just perfect to fit my 11'' wide rims back there. the 4.3L V6's with 5 speed manuals have 8.5'' rears with POSI's. do you think these will hold up to the 425+hp the nova is running?
Old 01-18-2008, 08:22 AM
Are you kidding me ??
No way ...
Old 01-18-2008, 10:07 AM
I suggest what an S10 owner might do. Many people with s10 and any kind of horsepower or large tires should upgrade to a ford exploder 8.8" rear end. They have a chance at living at those power levels.. 31 spline axle shafts, 3.25" outer tube, 1.32" axle shaft diameter, etc. They are so much stronger than a Chevy 8.5 from an S10 it s not funny. There is no comparing them. Its a quite popular axle for performance use. The mustang had a weaker version but the ring gear etc is the same size(28 spline axles on the mustang and ranger-certain rangers have 31 spline-rare). Huge variety of upgrades for these axles.. very popular for swaps...
1990-49 are drum.. 95+ are disc brakes! They are a bit wider, but not much than an s10. I think some explorer axles are different widths? bolt pattern can be changed... heres an s10 forum with more details on it
http://www.mys10.com/showthread.php?t=6545
P.S. don't get the price of my 8.8 exploder axles raised at the junk yards
Old 01-18-2008, 12:03 PM
302 Z28's Avatar
He he go for it, but don't get too far from home .
Vince
Old 01-18-2008, 02:36 PM
There are a lot of 9 second G bodies running the 8.5 rear.Standard equipment in the Grand National.
Old 01-19-2008, 12:17 AM
Sagacious's Avatar
why not?
im curious as to why not though... im running my stock 8.5'' 10 bolt 28 spline with 2.73 gears right now and i've beaten the hell out of it for the past two years. what makes the s-10 8.5'' not as strong?
Old 01-19-2008, 08:31 AM
Vortech 4.3's Avatar
jack of all trades
the 8.5 s10 rear is strong. there are 9sec cars running them. and i have heard of 10 sec cars running a 7.6 rear. i have a built 7.6 with a support cover in my truck. i am well over 400hp with 275-60-15 tires. i have fun driving it, and i race it sometimes. but i don't do donuts. its holding up fine( 4l60e trans). i am looking for a 8.5 for it. but the 2wd 8.5s are HARD to find. i'm probably going to get a zr2 8.5 and have it narrowed.
Old 01-19-2008, 10:58 AM
You guys are not trying hard enough.
I broke 12 bolt Camaro/Nova rear ends ... and I broke a few 9 inch 31 spline Fords too.
BUT ... It takes Horsepower and ... TRACTION ...
Old 01-19-2008, 11:07 AM
jack of all trades
yeah, well. i don't want that much HP. no need for it. 500ish is my goal.
Old 01-19-2008, 06:13 PM
S10xGN's Avatar
Gotta love a turbo!
Hope you've already got the rear axle. Very few S-10's ever had the 8.5" rear. I think you'll find that whenever you go "junkyarding"... The (31 spline) 8.8" Explorer is much stronger - actually Ford's remake of the 12 bolt. I have a (28 spline) Ranger axle in my S-10 and can rip off 12.0's @ 115 all day long.
Russ
Old 01-19-2008, 06:56 PM
302 Z28's Avatar
Randy, that is because they are all into smoking the rear tires , IE no traction.
Vince
Old 01-23-2008, 08:49 PM
Then there's the possibility that the S-10 rear might have the infamous Gov-Lock carrier.
Old 01-24-2008, 02:58 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
The 8.5 S-10 should have an Auburn-style cone limited slip if I recall correctly.
And there are TONS of us Impala SS guys putting 425 and more to our 8.5s; even using 383s, T56s, and 4.56 gears with DOT slicks. That's a lot of shock load. Properly set it up, it should handle a lighter Nova with no problem. The later 8.5s have 30-spline axles. Go for a ZR2 truck and get the disc brakes, too.
93 and 94 olds 98 wiring pinouts 4t60e Ninja2000 Transmission - Rearend 0 11-19-2007 01:46 PM
Swaping 10 bolt rear ends, what will fit? fansick Transmission - Rearend 5 07-13-2007 02:41 PM
Nova rear frame replacement straight6nova67 General Rodding Tech 7 01-05-2006 09:35 AM
10 bolt rear end. TORI1 Transmission - Rearend 1 01-04-2006 10:37 PM
10 Bolt Rear End TORI1 Transmission - Rearend 1 12-29-2005 12:02 PM
