93 Camaro converted to 96 Camaro LT1? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2010, 08:56 PM
Last journal entry: More information
So i took the 96 block to my engine shop, and it was shot -- rod had crashed into the block, and cracked it. Total rebuild cost 2500+. So i bought the 93/t56 package...
but that brings me to my question..
My 96 impala has pretty much EVERYTHING new on it (minus the engine). Coil, injectors, alternator, waterpump, optispark... you name it.
I know the 93 Camaro has a different cam so my 96 opti won't be able to be swapped without a cam swap -- my question is, will the rest of the stuff be easily swapped over to the long block? I'll have to get the PCM reflashed, but what other stuff is gonna have to be changed?
Also, if I was to do the cam swap, is it your opinion would it be cheaper to do the cam swap, or buy a new Optispark? Checking on rockauto, they go for around 400 bucks for an ACDELCO one -- pretty pricey.
Any input would be great!
Thanks
96 Camaro Battery problem... shysteeboi Electrical 5 10-02-2003 09:31 PM
LT1 out of 94 and up camaro postman Engine 0 06-15-2003 02:37 PM
BEST BOLT ON FOR 95 SS CAMARO LT1 LEADSLEDWAGON Engine 0 06-04-2003 07:09 PM
96 camaro rear end fit in 84 regal 225buick Transmission - Rearend 5 04-18-2003 05:10 PM
94 Camaro lt1 Vs. 95 Camaro lt1 NEEDHELP Engine 3 11-05-2002 12:45 PM
