93 cd wiring diagram??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-22-2003, 04:04 PM
79 pick up's Avatar
Lightbulb 93 cd wiring diagram???
hey I am trying to put a 93 cd player into my 77 granada!! does any one have the color codes for the wires on the 93 cd player it is a Ford cd player. Thanx
Old 06-24-2003, 12:33 AM
Silver_Camaro's Avatar
Superior Wheels Quality Tech
well.. lets see... yellow is usually a constant 12 volt source, red is switched 12 volt source (power is supplied when key is turned over), black is of course ground, and blue provides a 12 volt output when the radio is on to hook up a power antena or amplifier. the other wires should be speaker wires which are prolly one solid color and the same color with a black or white stripe for ground. you can find out which one is which by hooking the stereo up then hooking one pair of speaker wires to a speaker and using the fade and balance to figure out which speaker it goes to. Hope this helps.. If you have anymore questions just post em here. And always be as specific as possible.
Panther
Old 06-27-2003, 01:27 AM
Forkliftguy's Avatar
Crazy Canadian, woohooooo!
Have you had any luck yet? If not, I'm not overly familiar with fords colour codes, let me know (if you have the harness for that factory radio) the colours of each wire and which plug each one is in (some of the decks have two plugs instead of one), a picture of the back of the deck would help (but not necessary) if you have a digital cam. I'll try my best to walk you through it to find which ones which.
Marc
