93 chevy p/u door hinge - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2009, 10:31 AM
joe k's Avatar
I've got a 1993 chevy 1/2 ton pick up, and I'd like to change the drivers side door. The door I want to put on has one half of the hinge welded on . My question is how do I get the pins out to get the old door off, and will I need new pins when I go to put the new door on? THANKS
Old 07-08-2009, 11:20 AM
First, you need one of these to remove the spring in the hinge:
http://www.wescotools.com/p-2566-doo...-tool-aid.aspx
Once you do that, each of the two hinge pins has a sheet metal clip holding it in place. Remove the clips, remove the hinge pins, and the door falls on your foot.
Note that if you have power windows or locks, you need to disconnect the wires first. There should be connectors in the harness behind the kick panel.
Once you get this far, you MIGHTASWELL replace the bushings and pins. The replacements are inexpensive and these doors tend to wear them out.
65 Chevy P/U Drums to Disc brake change dar130 Suspension - Brakes - Steering 11 04-20-2008 11:01 AM
Motor mount location 1957 chevy p/u tejano66 General Rodding Tech 3 11-02-2006 08:58 AM
Frame prep. and coating on 89' chevy p/u Hazard Body - Exterior 3 03-27-2005 08:46 AM
FIRING ORDER FOR 3.1 93 CHEVY V6 DOBIED Engine 3 04-16-2003 03:12 PM
Need rearend for '55 Chevy p/u? amphib Transmission - Rearend 1 01-12-2002 07:11 PM
