93 chevy pickup 4L60E transmission, no 3rd or 4th - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2011, 01:06 PM
My '93 chevy pickup with 4L60 transmission, 4.3 v6, 2wd. The transmission steel feels strong in reverse and first two forward gears when shifts to 3rd actls like nothing there. even when manually shifted. any ideas or is it dead. 200,000 miles just started all at once
Old 06-16-2011, 03:35 PM
SSedan64's Avatar
Consider yourself lucky, most don't make it to 200K.
3-4 clutches are probably gone & it will require a complete rebuild.
Old 06-17-2011, 06:04 AM
Crosley's Avatar
Wiki Edits: 1659
The trans should be a 4L60E. Sounds worn out, 3 - 4clutches gone as mentioned.
z28 4l60e transmission turbofirebird350 Engine 2 12-01-2010 07:06 AM
1994 Chevy Suburban K1500 4L60e Transmission Problem rmar2010 Transmission - Rearend 2 11-29-2010 03:08 PM
Transmission 4L60E jessel81 Transmission - Rearend 9 05-19-2009 06:54 AM
4L60E transmission nastburns Transmission - Rearend 1 03-26-2009 02:22 PM
64 chevy pickup transmission slimfatboy07 Transmission - Rearend 1 05-24-2002 07:52 AM
