Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 05-21-2008, 11:05 AM
chevelle_502's Avatar
chevelle_502 chevelle_502 is offline
Get out the ducktape...
93 chevy with a quirk
I just finished putting a high volume oil pump in my 93 chevy 4wd. Got everything back together but its sat up a while and now it wont crank. Got fire to the spark plugs, getting gas (put fresh in the tank). I even put the #1 cylinder at TDC and made sure the cap and rotor were lined up. The truck will turn over and get to the point where its almost runnin but then falters. It even run briefly once. Am I missing some little thing or maybe some big thing? Anything to check that I may be missing?
Old 05-21-2008, 11:17 AM
Double_v23's Avatar
Double_v23 Double_v23 is offline
Horsepower Enthusiast
re: 93 chevy with a quirk
What was the rated pressure on the Pump? If it less then about 50 psi the engine may still not be getting fuel. Unless you swapped to a carb? Th
Old 05-21-2008, 11:39 AM
oil pump pressure? I know its getting fuel, I can see it coming out of the jets on the throttle body
Old 05-21-2008, 01:20 PM
Double_v23's Avatar
No I meant the rated pressure on the fuel pump you installed (which I see that is actually an oil pump) oops If you are getting fuel at the TB then it is probably up to the pressure you need.
Old 05-21-2008, 03:35 PM
T-bucket23's Avatar
T-bucket23 T-bucket23 is offline
Moderator
 T-bucket23's barnstar
Try advancing the timing a hair, turn the distributor counter clock wise 1/6 of an inch or so. It may be close but just a little retarded.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "93 chevy with a quirk"
List all of your cars HERE! Carbed95GT Hotrodders' Lounge 206 07-17-2008 05:19 PM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 43 03-09-2008 12:23 PM
9" to chevy conversion bigiron Transmission - Rearend 4 10-11-2005 09:32 PM
48 GMC and Chevy body parts inter-changability Neophyte Body - Exterior 7 05-25-2004 11:02 AM
New Member Introduction - 48 Chevy Rodder 48 Chevy Rodder Hotrodders' Lounge 0 10-20-2001 02:04 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
