93 chevy truck, rear differential questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-20-2008, 10:47 PM
chevydude1990's Avatar
93 chevy truck, looking for a rearend for faster road speed
hi im mike would a camaro rs rearend be faster than just was a 93 chevy halfton has in it?????thanks for all the help
Old 06-21-2008, 05:09 AM
poncho62's Avatar
Wiki Edits: 5
moving to rear end forum
Old 06-21-2008, 10:47 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Originally Posted by chevydude1990
ok is there a difference in a v8 rear end and a v6 well i have a 93 chevy truck with4.3 vortech im wanting to put a good fast rear end in it but i dont know what to out in it got an idea? thanks mike
Welcome to Hotrodders.
I edited your thread title from " I need help"... it is better to give us an idea what your "question is" in the title.
Please define :" im wanting to put a good fast rear end " .. Do you want higher road speeds ( lower engine RPM) ..?
Or so you want stronger acceleration?
A 4.3 powered truck may have a lower rear gear than the same truck with a V-8.. You can spin the tires and count the drive shaft rotations to get an idea of the gear ratio.
Old 06-21-2008, 02:42 PM
thanks you for the helf would a camaro rs rearend be better than just a half ton chevys jw
Old 06-21-2008, 11:44 PM
Camaro will be a 7.5" 10 bolt while the truck has the stronger 8.5" 10 bolt.
Shane
Old 06-23-2008, 01:24 AM
No Camaro rear end will fit in a truck without extensive (expensive?) modifications.
Old 06-23-2008, 02:52 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
Even if you were talking about an older 8.5 inch axle out of a mid to early Camaro, it isn't going to fit without modifications anyway, the spring pads are in different locations, and welded at most likely different angles, as well as the truck axle having either larger brakes or at least wider shoes and drums due to the extra weight.
The newer 7.5 and 7.75 inch axles out of Camaros are just plainly a downgrade in every sense of the word, if you were to go through all the effort of making one fit it just might not last for very long.
Old 06-23-2008, 03:20 PM
The first problem is, define "faster". To some people, "faster" means quicker in the quarter mile. To others, it means higher top speed. The gear ratio needed for these two things is completely different.
Hey folks, I'm just a girl. 1948 chevy 3100 truck parts questions ace101966 Introduce Yourself 12 08-26-2013 07:52 AM
84 Chevy truck 700R4 questions ChevyJim Transmission - Rearend 4 12-10-2006 08:43 AM
chevy truck rear end identification projectjohn Transmission - Rearend 9 06-18-2006 10:17 PM
1988 chevy truck, rear suspension and brakes cxpcman Suspension - Brakes - Steering 6 05-08-2006 07:43 PM
Chevy rear end swap Truplayainfla Introduce Yourself 1 10-23-2004 11:07 PM
