93 corvette 700r4 ???'S - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-26-2003, 11:56 AM
juveteach's Avatar
BUILD IT RIGHT, TWIST IT TIGHT !!!
Hello,
I was wondering if anyone could tell me the proper working pressures for the 93 700r4. Mine has between 125-135psi at idle and in park. Un-hook pressure is about the same. I can't speak of the pressures while driving as of yet have not had it on the road yet. The rev. pressures are a little high also around 175psi.
I just was wanting to know if they were in the ok range or are they high. It still has the fuel injected spring in the TV plunger(ie factory spring). If they are high will they harm the tranny,or is there a fix to this?
Thanks
