93 dakota no start. - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2006, 08:14 PM
Rubberman2003's Avatar
93 dakota no start.
My cousins 93 dakota will not start. He said it cranks over fine, but has no spark. He said it appears to have fuel pressure. Im getting it towed here tomorrow. I was just wondering of common things that break on these. He said he tried a new coil and it didnt help, and also an ignition rotor. I need to verify it is getting fuel. Dont the ecu's go bad on these trucks? Thanks, ill give you more info tomorrow,injp ect ect. Thanks
Old 03-04-2006, 08:25 PM
broncoII88's Avatar
Do the right thing...
Did he try putting on a new cap along with the rotor?
Old 03-04-2006, 08:29 PM
I dont think so. He said he is not getting spark at the coil either. He took the plug wire off the coil and checked for spark, and there was none.
Old 03-04-2006, 08:46 PM
65Stanger's Avatar
Check the water, check the oil
Check all the wiring first off. Once you make sure that your wiring is right, take a voltmeter to it and make sure you're getting electricity to everything. Change the plug wires and dizzy cap, and you'll probably get spark.
Old 03-04-2006, 09:01 PM
Well if its not getting spark down at the coil, would a cap and plug wires make any diffrence, assuming everything is getting voltage?
Old 03-04-2006, 09:23 PM
65Stanger's Avatar
YES! If everything's getting voltage, that's the only thing standing in the way. You can clean the points on the old cap, and try new plug wires first. If it sparks, it will be a good idea to get a totally new cap. Also, HEI? My mustang's got a standard ignition, so I have to constantly check my points.
Old 03-05-2006, 05:11 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
Check the crankshaft position sensor, if this is defective it will kill spark..and is the most common component to fail in a "No spark Condition".
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 10:45 AM
350 sbc upgrade... Engine will not start FenderGitars Engine 10 10-08-2010 04:26 PM
Starter Sizzle, No Start bjam2 Electrical 13 07-16-2004 05:32 AM
Won't Start after sitting?????Help! Weimer Engine 17 05-14-2004 01:36 AM
