'93 Dodge Dakota and a 440? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2005, 10:44 PM
Has anyone put a Chrysler 440 in a Dodge Dakota? I just bought two '93's for $2,000.00. One is the LE model, short bed with extended cab, it is clean and will be my daily driver. The other one is the Sport, short bed, standard cab, it needs some work and I'm thinking of putting a Chrysler 440 in it. Has anyone done this on the forum and if so could you post a pic and the problems you had doing the swap? I have done several swaps in the past so this is not my first. I have to go get my 440 in another town (it is mine) so I have been unable to measure anything yet until I go after it in the next week or so. Thanks
Old 07-12-2005, 11:16 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
yep, I've seen a 500 wedge in one. It can be done, but expect to cut some metal out. YOu'll need some stiff springs in the front too, no big D. I think those folks fabbed their own mounts, too. I guess that goes without saying.
K
Old 07-12-2005, 11:26 PM
K
Yes Sir, I figured on cutting metal out. Will know more when I go get my 440. Mounts I can do, no problem. I'm planning on using a 727 tranny so I'll probably have to "reshape" the tranny tunnel. Thanks Killer!
Old 07-13-2005, 03:41 AM
Crazy Mopar Guy's Avatar
Try these guys for a start....?
http://www.engine-swaps.com/frames/f...ck_Dakota.html
Old 07-16-2005, 11:23 AM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
I believe once I saw an s10 with a blown 454 in the back and a crappy stock 4popper in the front turning the front wheels, use the underpowered 4 for her, the "stupid noisy engine" for him, I guess.
If it were me, I'd just leave the 4banger in a cavalier or whatever. Not a bad idea trying to combine 4-cylinder economy with big-block power though, just 2 shifters, 2 clutches, and 2 throttle pedals I think would be really wierd.
Old 07-16-2005, 04:30 PM
A stock S10 is REAR wheel drive? How did the 4 cylinder drive the FRONT wheels!?!?!
Old 07-17-2005, 07:39 PM
broncoII88's Avatar
Do the right thing...
That is a strange machine! Your dakota is a 4x4 correct? I'm guessing that the t case will have to be moved back a bit since the new motor and tranny are longer. This means a little more sheet metal cutting. You'll need to modify the driveshafts too to compensate the length change. I've seen plenty of s-10's and a few rangers with huge motors, but never a dakota!
Old 07-17-2005, 09:18 PM
If you are talking the two '93's I (gcrmcc) bought last week niether are 4WD's. I didn't mention what they were. They are both 2WD's. Sorry for not putting the info in the first post.
Old 07-20-2005, 12:42 PM
broncoII88's Avatar
hen you won't have to worry!
Old 07-20-2005, 08:50 PM
Wiki Edits: 7
My only guess would be a driveline swap from a cav with some crazy fabrication of motor mounts. I swear I saw it in a mid 90s Super Chevy magazine. I think it was stupid to have a 4 in there, but the 8's not a bad idea.
Old 04-17-2007, 02:14 PM
I have done it
you have to do some cutting if you want to use some headers or make some. I used a set of headers from a 4x4 ramcharger but had to trim around the control arms also no cutting was needed to the trans tunnel, I used a motorplate for my mounts. you have to use a rear sumpp oil pan
Old 04-21-2007, 08:42 PM
Last journal entry: 7 Qt. oil pan installed
Here is a picture out of Mopar Muscle of a '93 Dakota with a HEMI. I live a few miles away from him. He goes to local shows, but mostly keeps it garaged.
