'93 ford tempo won't start. Need help pulling codes - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-20-2007, 01:10 PM
RodFather's Avatar
I smell like a hotrod!
Last journal entry: windshield
I know it's not my hotrod, but I need help getting the old daily driver to start.
I have a 1993 Ford Tempo. 4cyl fuel injected. Last weekend I didn't drive the car for 3 days, and we had freezing weather. I can not get it to start now.
First thing I did this morning was replace the battery and terminal ends because it was a mess. Car still will not start. It acts as if it's not getting gas.
I found a site that shows me how to pull the codes, but I can't find the STI connector. I found the 6 pin Data link connector that says EEC TEST on the cover, but I can't find the STI connector that a run a jumper wire to.
Any help is appreciated.
-Brian
Name:	sti connector.JPG
Old 01-20-2007, 06:39 PM
It should be right in the same vicinity of the EEC TEST plug. It's just a single wire with a plastic end fitting on it. Do some searching around the test plug. Unless someone cut it for some reason it should be around there somewhere.
Old 01-20-2007, 07:07 PM
driveability's Avatar
Last journal entry: 930 4 speed transmission
I think looking for stored codes is always a good way to go, however it sounds like you could go directly to a few tests like listening for the hum of the fuel pump. It should come on when you cycle the key "on" for a few seconds. Its likely if you wish to here again you will have to cycle the key off for 20 seconds for the system to go to prime again. I would start there if no codes are present and surely check for spark. You could also remove an injector connector and see if the harness receives a pulse during cranking using a test light. Keep warm !!!
Old 01-21-2007, 12:01 PM
RodFather's Avatar
Fuel pump is working. I rented a scanner, and it says the ECT Sensor is faulty. I am going to go buy a sensor now. That's the only code I showed. I will let you all know if it starts after I replace this.
Old 01-21-2007, 01:45 PM
RodFather's Avatar
Still not starting.
my plugs are wet with fuel, Plugs are getting spark.
My local autoparts store sold me a ETC Sensor, and it doesn't look like it's actually for my car. Does anyone know where I can view location or buy one online. The part store swears it's correct but it doesn't look like the one going into my thermostat housing.
Can a ETC Sensor keep a car from starting?
Old 01-21-2007, 04:07 PM
4cyl Pentastar Fanatic
Originally Posted by RodFather
Still not starting.
I have see bad temp sensors cause cars to stop running or enter no start conditions. The computer reads the temp of the coolant and alters the fuel tables based upon the input. I would replace the sensor and check the wiring first. Ensure that your auto shut down relay is not being tripped. If you are getting fuel pressure, it is not being tripped. If your Ford is equipped with that friggin inertia switch, check that too! That thing has suckered me a few times.
Try going to a decent parts store as well. The guys at NAPA or CarQuest always seem to be much more knowledgeable and helpful then the guys at AutoZone or Advanced, at least in my experience.
Another thing to check would be the Engine Coolant Temperature (ECT) sensor. If the ECT is telling the PCM the engine is hotter than it is, the PCM will lean out the full mixture, possibly to the point where the vehicle won't start.
Source: http://autorepair.about.com/library/a/1i/bl755i.htm
Old 01-21-2007, 07:02 PM
First I would hope you are looking at the correct temp sensor. If you don't have spark replacing the temp sensor wont help that. Good luck with your project.
Old 01-22-2007, 05:00 PM
RodFather's Avatar
I replaced the Coolant temp switch (one for the CPU in the waterneck not the one for the gauge). I pulled a plug and grounded it...it's getting spark.
I'm going to try changing the spark plugs because they are soaked in gas.
If that doesn't fix it off to the dealership it goes.
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 05:29 AM
Ford wont start please help. bowtieorbust Electrical 7 04-26-2004 04:29 AM
my 2.3 ford engine will not start pintoperformance Engine 1 10-05-2003 05:07 PM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
2001 ford pick up wont start right Clinton Hotrodders' Lounge 3 07-10-2002 04:25 PM
