Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - '93 ford tempo won't start. Need help pulling codes
Old 01-20-2007, 07:39 PM
Kevin Varnes Kevin Varnes is offline
It should be right in the same vicinity of the EEC TEST plug. It's just a single wire with a plastic end fitting on it. Do some searching around the test plug. Unless someone cut it for some reason it should be around there somewhere.
