93 mustang 8.8 axle questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2007, 01:16 AM
hello ive been searching the web for info on a 93 mustang 8.8 rear axle .can the stock axle be resplined?also is there a ford axle off a 4x4 with an offset axle width..in other words is there a swap for a shorter axle instead of cutting mine down.?i plan to shorten the housing.thanks for any help.
Old 02-13-2007, 05:46 AM
poncho62's Avatar
Wiki Edits: 5
I would ask this in the Rearend forum.......so the guys there can see it.
1990 8.8 posi mustang??? help!! inkfixer73 Engine 1 09-02-2003 11:43 PM
Rear End Replacement in 93 Mustang NavyGuy Transmission - Rearend 1 05-09-2003 07:29 AM
8.8 ford and 9" Hack Job ??'s ChopTop Transmission - Rearend 6 01-28-2003 10:48 AM
34 ford truck front axle ideas and questions lilred34truck Suspension - Brakes - Steering 1 10-30-2002 05:20 PM
Axle replacement for 68 Mustang rosw Transmission - Rearend 2 10-02-2002 03:30 PM
