93 Mustang EEC-IV Code 334 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-16-2006, 08:01 PM
I have a check engine light problem with my Mustang. The Actron tester gives me a code 334 which is the dpse on the EGR valve. I've changed that and checked for corrosion at the wire connection. By the way, It is a 2.3 dual plug 4 cyl.
Now I'm just plain lost. I have no idea where to go; I have the Ford manual but can't even begine to follow it as I don't have their testing facility. Can anyone lend a hand?....Thanx, Pliskin
Old 12-16-2006, 08:32 PM
It could be the valve itself. Start the eng up to operating temp. Take a mighty Vac hand pump or hook straight vaccum up to the egr valve. If the engine studders and boggs and or dies the EGR is working correctly. If stays running the same the valve could be gunked up with carbon or the egr passage could be clogged. I hope this helps you.
Tim
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
r&r ft. coils 93 mustang dlc427 Suspension - Brakes - Steering 9 04-18-2006 07:33 PM
93 Mustang rear end 9"? newchevyman Transmission - Rearend 2 05-27-2004 12:39 PM
Ticking noise in a 93 mustang lx.. Nos Engine 7 09-28-2003 01:32 PM
Rear End Replacement in 93 Mustang NavyGuy Transmission - Rearend 1 05-09-2003 07:29 AM
