Hotrodders Bulletin Board
#1
93 Park Ave Tilt Column Wiring info needed
I'm using this column in a project & I need a wiring diagram for the wiring in the steering column for a 93 Buick Park Ave. Mainly the turn signal, hazzard, wiper & cruz stuff.....thanks..joe
#2
re: 93 Park Ave Tilt Column Wiring info needed
Doc here,
All I have is info on a 93 Le sabre, Which should be CLOSE to the park ave, BUT Continuity check with an Ohm meter to verify Color and function are correct..It may differ... Windshield Wipers
BEAM SELECT SWITCH
TURN SIGNAL SWITCH
GEAR SELECT SWITCH.
Again, This pertains to a 93 Le Sabre..IT MAY differ, so check Color Vs Function with an Ohm meter first, But it Should be the same or very close. Hope it helps! Doc ![]()
Aftermarket Solutions Electronic & Electrical Innovations |
#3
Thanks Doc, I was hoping you'd show up w/some info, since it seems you are "da'man" when it come to the electric stuff in cars... thanks again ...joe
#4
Doc here,
Thanks! Let me know if the Color Vs Function is correct for your Column, If not I'll try to research an exact one for it.but I think it should be the same. Doc ![]()
Back to top |
Similar Threads for: "93 Park Ave Tilt Column Wiring info needed"
| can't find alternator wiring info i need | Neophyte | Electrical | 16 | 06-19-2006 09:34 PM |
| 1990 Full Size Blazer Steering Column problems..tilt | boneyard Buick | Suspension - Brakes - Steering | 5 | 02-08-2006 10:39 PM |
| 93 buick park ave. | Holly-Roller | Electrical | 5 | 09-25-2005 06:39 PM |
| Tilt Column for 66 GMC? | 66GMC | Suspension - Brakes - Steering | 9 | 06-14-2005 07:53 PM |
| 84 Grand Prix column replace info | Bee4Me | Suspension - Brakes - Steering | 4 | 02-08-2005 09:01 PM |
