Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 93 Suburban fuel pump
Old 08-21-2005, 08:37 PM
sabino56's Avatar
sabino56 sabino56 is offline
Thanks - I have shop manuals and found that there is a test point for the fuel pump on the diag connector under the dash - slot G. I could not hear pump when putting 12V to it or when ignition was on. I put test light on in-line fuse and could feel relay activate and light would go on when ignition was turned on. Then I put 12V on the downstream side of the fuse connector and pump still didn't seem to come on. I guess it's down to dropping tank.
