there should be a single wire, i dont know what color it is you'll have to check a service manual. but its a fuel pump test outlet. all you have to do is put that wire to a 12V source and see if the pump starts. an easy way to check is disconnect the feed line from the motor and put a bucket underit and see if it shoots gas out of it. and if you do get gas, then its not your pump.
and yes, the fuel pump and sender are all in 1 unit in the gas tank. |
Thanks - I have shop manuals and found that there is a test point for the fuel pump on the diag connector under the dash - slot G. I could not hear pump when putting 12V to it or when ignition was on. I put test light on in-line fuse and could feel relay activate and light would go on when ignition was turned on. Then I put 12V on the downstream side of the fuse connector and pump still didn't seem to come on. I guess it's down to dropping tank.
get you a good penitrating oil, my favorate is pb blaster, or aerokroil, aero is kinda expensive but works awsome... Since the tank is prety much empty you shouldnt have to much prolem. maybe the night before or a lil while before you tackle it soak the strap bolts and shoot the top to try and help the hold down ring to losen up. dont try and drop if its full, its prolly a 30 gallon tank.. After that i think its one wire conector and 2 or 3 quick disconect fuel lines and its out. im not 100% sure if its a giant snap ring or a lock ring you hammer side ways to get the pump out. then just make the sure the new one goes in in the same direction as the old and your on your way, fill the tank, the gas keeps the pump cool so it doesnt burn up.
Let's assume you have one big tank like my 94' Suburban. If so, here are some pictures to give you an idea of what's involved.
Make sure the tank is as empty as is possible! Two straps hold it on, pre-soak them as suggested. The tank will come out without having to jack up the rear. You will need a floor jack and a flat piece of wood about 2 foot long. A 2x4 will work okay, but flatter is better. You need to disconnect the filler hose at both ends, as well as the big 5/8" dia. vent hose at filler neck assembly. There is an electrical connection (weatherpack style) that is bolted to the top of the frame rail on the drivers side. This is also where the ground loop is attached. Drop the tank gradually and let it lean to the driver's side. This will allow you to get to the supply and return line couplings, and the other smaller vent lines. Disconnect the fuel lines, the electrical connection, and the smaller vent lines (need pliers) and then allow the tank to slide off the floor jack completely on the ground. Since there should also be hard plastic protective cover, it will allow you to slide the tank without worry of damaging it. If you remove the shield first, be very CAREFUL when dropping and sliding the tank. Pulling it out gives you easy access to the sending unit. Clean it off the top area real good and use compressed air if available prior to removing the ring. After you replace the pump, be sure to use a new O-ring gasket at the top and use grease to lube it, otherwise it may break when reinstalling the ring. Be sure to use the new section of hose that comes with your new pump and also install a new strainer. Buy a new AC-Delco fuel pump if you can find one. Reinstall in the reverse order. And, remember to have a helper when doing this job (lol - see my last picture). Good luck, Ed www.edgesz28.com |
Thanks for the great pics and instructions!! I'll let you know how it goes. It's going to be another week before I get to it. I've got to work on a tranmission replacement in one of my other cars this week.. bummer.
Thanks again Ed |
| Oil leaking near fuel pump..what the heck??? | HotRodF100 | Engine | 13 | 01-08-2012 05:03 AM |
| Ford 1 and 2 piece fuel pump eccentrics | lluciano77 | Engine | 17 | 10-09-2004 10:58 PM |
| electric fuel pump recommendations | stea | Engine | 2 | 06-27-2004 08:38 PM |
| Bad fuel pump??? | ffcagle34 | Engine | 2 | 06-20-2004 11:15 PM |
| Fuel Pump recommend? | 71 Red Sled | Engine | 2 | 01-20-2004 06:27 PM |
