'93 T-Bird Rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2002, 05:50 PM
Arrow '93 T-Bird Rearend
I have a 1993 Thunderbird LX, with a 5.0L V8 resting underhood. I know my way around the engine very well, I've worked on many a Mustangs with the 5.0HO in my life, so that is no problem to me. The problem here is the rearend. I know that one of the best performance boosters can be a better rearend. The only problem is, which one? And what all will i need to get it as best of performance as I can? Right now, I'm pretty sure it has 2.73's, but since there is not a lot of documentation on the net for that year T-Bird, I'm not exactly sure on that. It sure doesn't feel like anything higher. It has the standard Ford AOD tranny in it, so gas mileage, at least on the highway, won't be affected to much by putting 3.73's or 4.10's in it, i know that. I consulted my local mechanic (who i trust with my life) on that one. Which would be the best bang for my buck? 3.73's, 4.10's, or 4.30's? And, along with the gear, what else would i need to purchase to make sure it all goes smoothly?
Your input is greatly needed in this matter.
-Steele
Old 09-02-2002, 10:05 PM
Post
I have had alot of AOD 5 liter's and I would say that 3.73 would be a minimum for an enthusiast car. If you want to drag race it for best 60 ft. times I would say 4.10 or even a 4.30 wouldn't be too low if you are going to run 28" tall slicks. But this is just my opinion.
Old 09-03-2002, 02:11 AM
aka Duke of URL
Arrow
[quote]Which would be the best bang for my buck? 3.73's, 4.10's, or 4.30's? And, along with the gear, what else would i need to purchase to make sure it all goes smoothly?<hr></blockquote>
Basically, any performance mod you make to a MUSTANG can be performed on your BIRD. Do you know your ring gear size (7.5 or 8.8)?
3.73 would be best for street performance along with a Traction-Loc upgrade.
Old 09-03-2002, 08:40 PM
Post
I have been told that all 5.0L T-Birds after 87 were 8.8" in the back, but i'm not positive. is there some easy way to tell short of lifting the car?
Old 09-04-2002, 01:24 AM
aka Duke of URL
Arrow
There should be an assembly I.D. tag located on the rear cover.
Post the codes.
