93 T-Bird stuck odometer - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2005, 07:22 PM
Speedo on my '93 T-Bird works fine but odometer seems stuck, doesn't add any miles. Bought it like this about a year ago. Anyone know how this works? Maybe something is unplugged, or do these odometers just go out sometimes? I need to know how to get it working or replace it. Thanks for any help!
Old 08-02-2005, 01:18 PM
try www.carradio.com
Old 08-02-2005, 01:45 PM
docvette's Avatar
Wiki Edits: 12
Speedo
Doc Here,
Usually on Non~Electronic Speedos, the gear drive for the Numeric Readout Rusts up, and can not be driven by the Main Weight body.
You Can try to remove the Cluster , half the speedo, and soak the numeric readout in WD40, let it soak awhile, and try driving the unit with a Drill motor.
The reason the Numeric Readout locks up and not the MPH clock is because the MPH readout Relays on very little force to move it, and the readout is solid mechanical..The drive motor is nothing more than a magnet spinning inside a metal drum...with little torque.
Legally, If you repair it, you need to make an estimate of the miles it was in-op and report it when you change title, but I doubt anyone ever does...
Good Luck!
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 08-02-2005, 06:51 PM
Thanks to both!
Anybody else? Anyone know how hard it is to remove the cluster and speedo? I suspect the steering wheel comes off first and everything pops out that direction. Anything that requires special care to disconnect/remove?
Old 08-04-2005, 11:50 AM
can't say on the 93...my 95 was fairly easy...just the screws holding the cluster
Any tricks to get off a STUCK oil filter?? 78SilverShark Engine 81 05-19-2008 04:19 PM
95 camaro stuck in neutral solgood71blazer Transmission - Rearend 2 12-13-2004 01:06 PM
rolling back odometer Berliner Bel Air General Rodding Tech 11 03-20-2004 02:36 AM
windsor in a 93 t bird need help stiffler197 Engine 1 01-19-2004 10:50 PM
im stuck....cant decide shesmy63 Engine 7 07-21-2003 10:13 PM
