93 tbi - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-02-2008, 01:43 PM
93 tbi
i have a 93 1500 z71 4x4 with a 350. when you crank it it over it will not start but if you add a little fuel in the tbi it will start and will not idle but if you do this and keep it above 1000 rpm it will run and drive. i have put a kit in the tbi and a new iac valve. any ideas??????
Old 11-02-2008, 05:08 PM
Any codes? What is your fuel pressure? Are the injectors putting out a nice spray or a stream/drip? A timing light can help you see the fuel spray pattern.
Old 11-02-2008, 08:54 PM
Are the throttle blades open a little? If not it can't get fuel and cause the issue you are describing. Try cracking the throttle slightly and crank it see if it starts.
Old 11-03-2008, 08:38 AM
racecar100's Avatar
You should have 12 pounds of fuel pressure. If not you need new fuel pump.
Need some help with 1986 GM 305, TBI or Carbed??? dieselcruiserhead Engine 8 12-19-2010 08:32 AM
TBI to carb swap eatonde Engine 20 09-09-2008 12:01 PM
TBI assistance needed jack kelley Engine 5 05-24-2006 11:11 AM
Tbi Mods NAIRB Engine 8 05-03-2005 07:50 AM
TBI Questions on a 93' Chevy FS 350 IWANTMOREHP Engine 1 01-04-2004 02:42 PM
